-   -   92 Isuzu Trooper Axles (https://isuzuforums.com/forum/trooper-18/92-isuzu-trooper-axles-1510/)
xqzitkid Nov 17, 2007 10:19 PM
does my trooper front axles have a front locker while in 4 wheel low?
atfdmike Nov 20, 2007 01:39 PM
the stock Troopers only had an Isuzu LSD (limited slip dif) in the rear, so I doubt that you have one in the front unless someone installed it. If you have a locker in front, they are great off road but on surfaces with traction they tend to only want to go straight so are tricky to drive when you need to turn.
Hope this helps
xqzitkid Nov 20, 2007 02:52 PM
I wanna put an Arb air locker in the front. Is there anyway to lock the rear besides welding the gears together?
tripjax Nov 23, 2007 02:01 PM
They make lockers for the rear too, saw one on ebay a while back.
