91 trooper auto to manual
Alright so I just bought a 91 trooper, I love that thing! Now the queation is, I found a 89 trooper that is a manual(my trooper is auto). Now I was thinking about taking the tranny and all thay from the stick and put it in mine. I would like to know if the mounting brackets and and everything else will line up. And any other wisdom you might have.
Thank you |
No they do not line up. The transmission mount is further back on the automatic. If you can cut and weld you can transfer the transmission mounting plate from the 5 speed frame to the automatic frame and then bolt it up. You're doing it the right way though, buying the whole truck is a smart thing to do, there are a lot of parts that will need to be swapped and added to get the conversion done, but at least you'll have them instead of trying to piece-meal it all together.
Ok so jhonny5ive, your saying that if I cut the mounting brackets from the stick and weld them onto my auto, it will mount up. That sounds easy enough ha, yeah ok :P
But will every thing else line up and go in all good? Also what else are you saying I will need from the stick... Wait (stupid question) but the stick can go into my 4*4. I'm assuming that all troopers were 4*4. |
Yeah, everything else will bolt up, you'll have to change the driveshafts, add all the clutch pedal parts, master & slave cylinder, etc, but it'll go right in. Keep your auto radiator in there it cools better. You're going to have to either bypass your park/neutral safety switch or route it to the clutch pedal like they had it on the 5 speeds... It's not a big deal man, if you've got the tools just move everything from the 5 speed truck to the automatic truck..
Ok so now I just thought of the computer.. fo I need it from the stick. If so, are the plug ins the same as my auto?
