-   -   89 Trooper start/idle problem (https://isuzuforums.com/forum/trooper-18/89-trooper-start-idle-problem-38685/)
acmodeler Feb 1, 2012 07:48 PM
Have an 89 Trooper with 150K. When starting it requires high RPM, 3000, to keep it running for the first two minutes. It then idles properly and runs well. Shut it down and repeat of the same problem but if it is still hot less time at high RPM is needed.
I've checked the air flow valve and fuel system. Anyone know the solution to the problem?
joann.jimi Feb 21, 2012 02:18 AM
Check the spark plugs, check the IAC to see if it's dirty. If the IAC is dirty you can clean it with seafoam or another type of cleaning agent.
acmodeler Mar 5, 2012 08:56 AM
Iac
I just spent many hours replacing the IAC and hope to have it running shortly. I appreciate the response. Your the first from numerous forms that gave any type of knowlegeble advise. I will advise if that fixes the problem.
harrybuckner Feb 17, 2013 03:44 PM
Did you have any luck? I have an idle that won't come down from max.
