1990 Trooper - Chewed on COIL Wires
PS- It's really a 1990... Folks, it's hard to believe but a Wood Rat chewed on my Trooper's Coil 12v feed.
From what I was able to gather there are two wires associated; a blue and a yellow lead. What I don't know is what color wire goes to the upper-most pin on the Coil? Attachment 361 |
I rec'd this reply from another forum:
Top blue, yellow bottom. |
That's bad. That is exactly why I hate rodents.
Yeah, Thx Dreamer. Since then I fixed those Coil wires but found these others- (I think they may be Corner Lighting related but not yet sure...)
Attachment 360 ORANGE & YELLOW wires are completely chewed through, the GREEN wire is only chewed on, they are bundled up with the Big Ground Strap on that side of the Engine Bay but I'm not 100% sure what they serve... |
That sucks. The problem seems to be a lot worse than you expected. You have to consult an electrician.
Stuff just keeps getting better and better... Attachment 359
well.. i have chewed too the, orange & yellow..
where goes? |
Originally Posted by foxgenco
(Post 88568)
where goes? |
| All times are GMT -5. The time now is 04:02 AM. |
