I have a 93 trooper, 5 speed, when I put the car in gear (any gear), the car does not move, it acts as if the clutch is not releasing, the engine revs up, and the truck sometimes moves very slowly, so slow is not even safe to drive. I need to press the clutch to shift gears, does not shift without pressing clutch, but when I release pedal, it comes back up, however the vehicle does not engage, motor revs up, but no movement, even on reverse. Any suggestions? I was thinking to replace the slave cylinder, but I''m not sure if it''s bad since the pedal comes back, does not stay down against the fire wall. bled that line just in case, but nothing happened. Thanks. |
