| aftrooper |
Dec 26, 2010 01:08 PM |
4WD Problem
Having an issue with my 4wd not working. Can't find a Haynes or Chiltons at any of the local auto parts stores to fix the problem. Just wanted some suggestions on what may be causing the 4WD not to work. I am not too familiar with the Isuzu drivetrains. My 99 trooper has a Electronic 4wd Auto button and a manual lo/hi shifter. The issue is that it has its own check light that begins to blink after a couple minutes being turned on.:mad: so i am not sure if it is a sensor or something mechanical. i have only owned the vehicle for 6 months and dont believe the previous owner ever used the 4wd. will someone be able to give me some ideas of whats wrong:cool:?
