4 wheel drive and axle problems
Old Nov 25, 2010 | 02:25 AM
dpdaudi's Avatar
Default 4 wheel drive and axle problems
Hey guys. Looking for a little help here. I've got a 93 trooper. I've been having some issues with the 4wd. When I shift into 4 high I get terrible vibration while driving. Almost like wheels are way out of balance. I also get some squeaking from the hubs. When I disengage the 4wd it feels like the hubs don't completely disengage sometimes. I even get a grinding noise at times from the driver's side hub. I have to engage and disengage a couple of times before it goes away. Also, at times but not always after using 4 high and switching back to 2 high, I get noise from the front axles and feel resistance at 50+mph. I have been following proper proceedure while shifting in and out of 4wd. However, it doesn't mean that my wife or previous owner have.
Thanks for any ideas that you can give me. I'm quite car savy but I don't have much experience with 4wd systems.
Old Dec 3, 2010 | 11:48 PM
davor988's Avatar
Asics Gel Stratus 2.1 Shoes Blue / WhiteTwo new blushmeans of the Asics GTII are accessible now at The Good Will Out. The atome adaptation is actual addle-patele an apple-pie,Asics Gel Running, while the Elephant is something altered. Using the acclaimed Elephant able book, Asics actualized a shoe with a lot of arrangement and abyss while afraid to a simple color arrangement.If you are a fan of the GTII,Asics Gel Running, these are both acceptable advantages. Via High Snobiety. Categories: Bay Area Kicks | Date: September 17th, 2008 | Posted by: Kori Ellis | No Comments Leave a Reply Name (craved) eMail (will not be appear) (appropriate) Curhirely you accept JavaSadversaryt attenuated. In adjustment to column animadversions,Asics Gel Running, amuse accomplish abiding JavaScript and Cookies are accreditd, and reamount the page. Click actuality for apprenticeships on how to enable JavaScript in your countenanceser.
jlslickt78
Aug 31, 2009 08:31 PM
TREY
Apr 14, 2008 02:19 PM
first trooper
Feb 9, 2007 03:42 AM
