3.5L Trooper Engine Failures
Old Jan 17, 2008 | 10:42 AM
ScubaDave's Avatar
I have a trooper that was loaned to me - a '99 4WD Auto - but when I went to pick it up, the engine siezed up. I have seen a bit of discussion on this being a problem with Troopers of that vintage, but was wondering if it is a common problem or a random event? Does anyone have any insight to it?
Ineed to decide whether to repair the vehicle - replace the engine, a fun project - or to write it off. The vehicle itself is in very good condition having been gently used. But, a $3,000 cost of a rfeplacement short block is probably as much as the vehicle is worth at this point. I don't mind the work, but I want to make sure that I won't blow another engine five miles down the road.
Please give me any insight around.
Thanks!
_uacct = "UA-939292-44";
Old Jan 17, 2008 | 10:47 AM
ScubaDave's Avatar
Sorry for the almost duplicate message. The forum error processor said this post wasn't done and I posted another before I thought to check if it was there for real or not.
Old Jan 17, 2008 | 02:07 PM
atfdmike's Avatar
Yes, there is a known history on this motor...owners either seem to get a good one or a bad one...not too many in between. It is also an expensive motor to repair when it does go bad.
Here is a link to a very informative discussion on this motor.
http://forum.planetisuzoo.com/viewtopic.php?t=1914
I hope this helps you make up your mind.
Before I forget, welcome to the forum!
Old Jan 19, 2008 | 07:22 AM
ScubaDave's Avatar
Thanks for the link to the insight. It sounds like if I'm lucky and follow an increased oil change regimine, I could do very well with the vehicle. But, it doesn't sound like my old Explorer that ran no matter how I abused it.
I appreciate you assistance. I think I may go through with the replacement as a good project anyway if I can find some good advise on the best procedure. I like this type of fun. Have always been a bit of a tinkerer anyway.
Best regards,
ScubaDave
Old Jan 27, 2008 | 03:40 PM
SLXTROOPER's Avatar
Have u looked into JasperEngines , engine seized on mine too. Replaced with a Japer Engine and install kit radiator, water pump , oil pump etc. cost with labor just short of 10k. [img]smileys/smiley3.gif[/img]< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
91isuzupup
May 24, 2006 05:39 AM
gforce
Mar 3, 2006 07:43 PM
Katrina
Dec 5, 2005 05:09 PM
Frugal
Aug 6, 2005 01:51 AM
