2002 Trooper loses propulsion (tranny?)
· Problem developed over three short drives.
· Everything running fine, then it loses power. Engine continues to run smoothly. Only partially the first time, then completely the final two. · Transmission fluid level is fine. No apparent leakage and smells fine. · No warning lights · Engine does not rev, the vehicle just loses power after warming up. · Works just after starting up but loses power to nothing after about 2-5 minutes. Engine idles fine and revs if you push the accelerator… just no propulsion. - Can anyone give me some ideas? :confused: |
Start by getting the ECM codes read. Most auto parts stores will do it for free.
