-   -   2001 Trooper Trans Fluid (https://isuzuforums.com/forum/trooper-18/2001-trooper-trans-fluid-2495/)
josenangela Nov 6, 2008 12:38 PM
I have a 2001 Trooper. I cannot seem to find where to check or fill the transmission fluid. Any help out there? I do not have the owners manual. Thanks in advance!
gnr_70 Nov 9, 2008 03:32 PM
I don''t think there is one.
If you have noticed any shifting difficulty, then tranmission fluid is either needed to refill or completely changed.
my 98 trooper''s also does not have any dipstick to check t-fluid level.
go to the front passenger side''s bottom and locate the T-pan. you should be able to see a bolt underneath it. this is the drain plug. feel around the top of that pan and you will notice another bolt, this is where you need to fill the t-fluid. Fill it until it overflows, clean up any mess and tighten the bolt.
if you''re still not sure, head to the local library and see if you can find a manual for your model year.
