2001 Trooper Runs for 3 seconds then quits
I have 2001 Isuzu Trooper that was driven through mud puddles over the headlights several times. The Trooper made it home with no problems and the engine was rinsed off. It sat for a day and now it will start and run well for 3 seconds and then quit. It has been in this condition for 3 months.
Parts that have been replaced without success. ECU module Throttle body/position sensor misfire sensor Mass Air Flow Fuel Filter Starter Battery Ignition and fuel pressure are good. Codes that displayed are 1290 1299 1295 1515 Codes have been cleared and the engine will not run long enough to generate new ones. The Reduced Power lamp illuminated when the engine is running. Any advice is appreciated. Thanks. |
