rjones35 |
10-23-2010 05:19 PM |
1999 Trooper issues
Hello, new to the site!! I'm having a problem with my 99, getting a misfire on cyl 3 code. First off, where Is #3, middle passenger side? It's got 170,000 on it, got some exhaust leaks, maybe causing problems? I thought it was the middle passenger side, and I've replaced plug and coil, also switched Injectors, hasn't changed anything. Am I on the wrong cylinder to begin with?? Anything else I should check? The problem only shows up after the engine Is warm, and idling in traffic or whatever? Help would be great, thanks!!
