1997 Trooper question, is there enough...
Is there enough room behind the upper part of the console, where it rises to meet the vertical console assembly, to install 2"1/16 gauges? Keep in mind I''m asking for depth behind the face of the console. The section I''m speaking of is just north of the console shifter where it makes an almost 90 degree turn upwards to meet the bottom of the upper console as it''s coming down. My Oil pressure gauge is out and it''s too expensive to replace with that boring old original. I figure if I''m going to spend the money that I should get something I like.
Actually I want to mount two gauges down there, side by side, one oil pressure and one transmission temp gauge.
