1993 trooper window switch problem...
Hello all, Thank you in advance for reading this and hopefully sharing your insight!
My passenger window will not roll up, my son rolled it down for just a minute then it would not go up. I switched it with another window control switch, thinking that maybe the switch contacts needed cleaning, but it still is not working. I checked the fuses but none are blown. :eek: It is raining now and I am hoping someone can tell me where to go from here. Thanks again for your time and response!!!:) |
Yes check the switch and also check the motor. because sometimes the motor got burnt due to some hard up and down of the window because when the dust stuck in door panel and windows glass so it effect the motor power. There are some change of gears may be gone flat due to this consuming more power of power window system. Anyhow wish you Good luck.
