-   -   1993 trooper rs (https://isuzuforums.com/forum/trooper-18/1993-trooper-rs-39629/)
terryswagger Dec 11, 2012 04:45 PM
1993 trooper rs
Ive had this trooper for two years with no problems,everything was working fine, Yesterday my low fuel light went on so I stopped to get gas. When I started it back up my low fuel light stayed on, my O2 light was on, my battery light was on, my brake light was on and my cruise was on and would not go off and does not work, my blower motor stopped working, and Im losing voltage as I drive, It will start and drive but the voltage drops off, I have not tryed it with lights on. Ive checked the battery, and removed and replaced the connector on the ECM. I was unable to find the ground connection so I havent been able to check the ground, what could make all these happen in a span of 5 minutes? Im guesssing the ECM but need advice if this has happened to anyone else before, Thanks
terryswagger Dec 19, 2012 11:22 PM
Zero replys forum? Yur kidding right?
66low Jan 17, 2013 03:03 AM
try this forum
its very active
terry :/
66low Jan 17, 2013 03:04 AM
http://www.clubisuzu.com
as above =]
ThereGraye Jan 30, 2013 12:01 AM
Zero replys forum?
