1993 trooper rs
Old Dec 11, 2012 | 04:45 PM
terryswagger's Avatar
Default 1993 trooper rs
Ive had this trooper for two years with no problems,everything was working fine, Yesterday my low fuel light went on so I stopped to get gas. When I started it back up my low fuel light stayed on, my O2 light was on, my battery light was on, my brake light was on and my cruise was on and would not go off and does not work, my blower motor stopped working, and Im losing voltage as I drive, It will start and drive but the voltage drops off, I have not tryed it with lights on. Ive checked the battery, and removed and replaced the connector on the ECM. I was unable to find the ground connection so I havent been able to check the ground, what could make all these happen in a span of 5 minutes? Im guesssing the ECM but need advice if this has happened to anyone else before, Thanks
Old Dec 19, 2012 | 11:22 PM
Zero replys forum? Yur kidding right?
Old Jan 17, 2013 | 03:03 AM
66low's Avatar
try this forum
its very active
terry :/
Old Jan 17, 2013 | 03:04 AM
66low's Avatar
Old Jan 30, 2013 | 12:01 AM
ThereGraye's Avatar
Zero replys forum?
mpowell
Jul 11, 2009 08:18 PM
ladymacbeth
May 24, 2007 12:53 PM
EDDYFLY55
Feb 16, 2007 09:26 PM
magic
Mar 3, 2006 07:58 PM
