1992 trooper starting an idling problems
Old Jan 29, 2013 | 01:21 PM
dhiga's Avatar
Default 1992 trooper starting an idling problems
hi my name is David I just but a 1992 Isuzu Trooper with a 5 speed transmission I want to find out if what can be done to fix the starting problem since it takes a very long time for it to start. and the idling is inconsistent.
Old Jan 30, 2013 | 08:32 AM
ericgarwood128's Avatar
The most common reason your car won't start is a low battery. If you have a battery tester that can measure cranking amps, test your battery to see if it's weak. If you can't test it yourself, you can test the battery indirectly by jump-starting the car.
Old Jan 30, 2013 | 04:17 PM
DuncanMc's Avatar
Any ideas on the problem if it acts as though the battery isn't even connected yet you know it's fully charged?
Tmcd89
Feb 4, 2015 09:17 PM
trooper505
Dec 13, 2009 05:38 PM
caribe442
Dec 28, 2007 06:17 PM
HERGERTK
Dec 3, 2006 03:03 AM
Rock72
Nov 4, 2006 03:51 AM
