1991 Trooper 2.8 V6 questions
Hi all,
I just registered onto this forum. I own a 1991 Isuzu Trooper 2.8 V6, 5speed. It has193k miles on the original engine. Bought it when it had 160k miles. Still running pretty good. The engine is a bit weak though (esp. when I pull my fishing boat).Anyway, I have a couple questions.
1)At some point I mayreplace the engine with a rebuilt one. The guy I bought it from said he thought I could put a stronger 4.3cyl V6 in there (he said the 2.8 V6 that is in there was from GM (used in the S10 blazer??), and that they could upgrade it to a 4.3 with slight modifications). Does anyone know anything about whether I could do this or if this would be advisable? I am just looking for a bit more power if I ever decide to replace the engine. I like the truck a lot and want to keep it for some time, so am willing to invest a bit in a good engine if need be.
2) Since I have owned the truck the back brakes make a loud squeaking (almost rubbing noise), similar to what you would get when your brake shoes on your bicycle would rub on the rims. The mechanic I go to tells me that is common with Troopers. He said the brakes are mechanically sound, it is just an irritating noise. Is this something I could fix with a pair of new rotors and better pads.
Thanks in advance for your input.
Jerry
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
I have a good used motor here with only 109k miles. Near Toronto Canada. Where are you?
Bob
if you want more ponys for your buck that 4.3 is the way to go, plus there's a hell of alot more upgardes you can get for it, like vortec heads, superchargers, beefier cams, headers, i know alot of s-10 guys that can smoke the sh*t out of their tires up to 3rd gear with a stocker 4.3, but if your still leary about making the change over to a bigger motor do some parts research on them,oh & on your brake issues, mine do the same thing
Originally Posted by jerrysza
Hi all,
Jerry
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
Edited by: JLEMOND
