1995 trooper bogs and then stalls at wide open throttle
Trooper 1995 has been sitting for six years drove fine for awhile after I got it and then it started to gradually overtime started the bog after applying throttle would have two WOT in order to accelerate or barely navigate over a hill about a month or two after this condition revealed itself the catalytic converter caught fire so then removed catalytic converter even though I removed the catalytic converter acceleration condition did not improve but stayed the same figured screw it continue to drive it for a little bit then after complaints about my loud pipes I bridged the gap in the exhaust line from the removal of the catalytic converter and now that the muffler is attached the engine pawgs and then stalls at WOT
I have replaced idle air control valve spark plugs plug wires air filter and have also removed catalytic converter and completed the exhaust pipe where the catalytic converter should be
