Can anyone tell me what the three sensors are on the passenger side of the engine? They''re on the water jacket.It''''s a 2.6 ltr. I assume one is the heating sending unit to the gauge but not sure which one that is and what about the other two? If any these are bad will it prevent the engine from cranking? Also I had a mechanic put a new head on the engine for me and now he is stumped. He thinks he has swiched some wires around or the timing is off but when you turn the key over the motor just spins. It doesn''''t try to crank. He has checked everything. Plugs have fire, there is gas going to the throttle body and plugs and there is fire going to the throttle body. So everything that needs fire is gettin it but it just won''''t crank up. Any help on either question will be gladly appreciated. Thanks. Edited by: Dixietrooper |
