01 Trooper Rear Suspension
Old 06-01-2018, 08:10 AM
dwsschatte's Avatar
Default 01 Trooper Rear Suspension
Just purchased an 01 Trooper Limited. Front end seems tippy and bounces 4 or 5 times after a bump. The rear end slams with a loud bang sending a decent jolt up through the chassis.
A cursory look at the suspension nothing seems obvious. Got shocks on the way, obviously was at overdue. What else to consider? I am new to Trooper ownership.
Old 06-01-2018, 12:50 PM
dwsschatte's Avatar
Default Update
Underneath today to give the shock mounts a shot of penetrating fluid prior to replacement. The lower bushing on drivers side I could see under it. Between the bushing and the mount. Frame mounted bump stops could use replacement.
1986Trooper
05-30-2012 02:06 PM
TrooperRookie7
10-11-2010 01:32 PM
Stormtrooper211
05-13-2009 04:21 PM
oxyman
04-04-2009 11:13 PM
john banks
10-27-2008 08:24 AM
Quick Reply: 01 Trooper Rear Suspension
