1987 Isuzu Trooper ii 4x4 2.3L gas
Old 05-16-2018, 10:31 AM
Shain5x's Avatar
Default 1987 Isuzu Trooper ii 4x4 2.3L gas
What’s they best way to test my fuel pump or any other troubleshooting for fuel issues out side of my relays?
Old 07-13-2018, 03:27 PM
sundug's Avatar
Depends what the symptoms are, but I'll assume won't run, no fuel. My 1986 Trooper 2.3 gas came with a mechanical fuel pump, located under the intake manifold. I would start by looking at the front of the carb, there is a glass letting you see into the float bowl. If you can't tell if there's fuel, try pulling the fuel line off the carb , sticking it in a can, and safely cranking the engine to see if you are getting fuel. No fuel? There is a fuel filter underneath the vehicle, just ahead of the RR tire, inboard of the frame. Check that.
Trax
09-17-2010 01:51 AM
antdhernandez
05-10-2010 08:29 PM
Mrs T
09-20-2008 06:15 AM
DallasTrooper
04-22-2007 11:06 AM
Quick Reply: 1987 Isuzu Trooper ii 4x4 2.3L gas
