Lift kits for 2000 trooper 3.5
I liftedthe front of my trooper by just cranking the torsion bars. I cranked them enough to get about 3 inches. I also bought some taller coils from independent4x.com for the rear. Then i bought a 3 inch body lift from independent4x.com. I have about 5.5 or 6 inches all the way around right now. I clear 35 inch tires no problem, no rubbing.
I send you pics if you want.
_uacct = "UA-939292-44";
www.independent4x.com will have anything you could want to put on your trooper. if you are someone who wants true offroad use from it, thenthere is no other way to go. if all you want to do is cruse the streets, then just cranking your factory bars will work.
terrytcl
Feb 28, 2006 08:57 PM
