wiper control
the wipers on my wife's rodeo (1999) are acting strange. The are not returning to the rest position and the intermintent wipers are not working. I know that this is probably caused by a control box somewhere. 1 where is the box. 2. does anyone know the actual name and where I can get one. The dealer wants 225.00 for it and would not give me the part number or name. Any help would be appretiated.
Thanks Rich[img]smileys/smiley16.gif[/img]
I have an older Rodeo with the puch button controls. I presume the '99 has the multiple-function stalk. If so, you'll need to replace the combination switch. You can also open up this switch yourself to repair it. I did that with my turn signal switch. But this all requires opening the steering column to extract the switch. I don't know the part number, but you can try searching an after-market online vendor for "combination switch". Try http://www.isuzupartstore.com
u need the alarm and relay control unit, it is located behind the glove box and 2 the right u will see 2 modules one is sideways and one is standing up u need the one farthest 2 the right and is standing up
I've also done something like yours, I just replaced the GM turn signal switch and it was fixed immediately... With regards to your wiper, I think you have to fix the control box... Good luck...
Wish I would have seen this before. I havent been on this board for a while though.
Wiper relay replacement:
http://forum.planetisuzoo.com/viewtopic.php?t=5608
