trouble setting timing - 2002 rodeo 2.2L
Hello,
The previous owner stripped the heads off the bolts on the crank pulley so I am unable to take the pulley off to see the timing mark. Is there another way to check the timing? Will a timing light work if I rotate the crank? Thanks, -Mark |
Hmmm, I think i am going to try another trick like putting a pencil down the #1 cylinder and rotating the crank until I find TDC.
