Trouble 95 Rodeo 3.2 / Popping Sound
I own a 1995 Isuzu Rodeo 3.2 6L 4x4
I'm not sure if all this related, but I want to be sure that I put everything on the table. Of each incident listed below, there were no signs that anything was going bad.
The pops are frequent like popcorn, they sound like someone tapping their finger nails on the roof, but a little more electric & deep (just a little). Almost like the sound of lifting a Coil Pack while the engine is running. They are loud, very noticeable. Driving behind a Semi-Truck on the Interstate made no difference either way. There are no lights flashing and the truck runs great. It's just the sound. I would dismiss it as something loose if not for the fact that both the Alternator and Coil Packs went out the day before. In the last 6 months, I've gotten a new Timing Belt, Water Pump, Alternator, Tires, o2 Censor & Plug Cables. Could this be related to when I hit a bump? Maybe the tires are out of balance, though the bump wasn't too bad and it doesn't explain the other problems. Any thoughts? :confused: |
Update
It took a 13 year old to figure out what four 4 mechanics couldn't - not to mention the $300 in unnecessary parts, a full day, a tank of gas and a lot of stress. Turned out being the strip between the front window shield and body, it was loose. Nothing a little duck-tape can't fix until I get to a store. Just wanted to update this post in case somebody else has the same problem. |
