transmission shifting problems
Old 11-19-2007, 10:54 AM
justanox's Avatar
I have a 2002 Rodeo 4x4 with a v6 engine. When I get on the interstate and go above 70mph, the transmission shifts real hard, then the check transmission light starts flashing and every gear shifts hard. however, if i turn the vehicle off for about 5 min, it will quit doing it! Also, when I let off the gas at highway speeds, the Engine RPM's fall completely off and when I push on the gas pedal again, it takes it a minute to catch up to how fast the car is going......can anyone help?
thanks
Old 11-19-2007, 07:58 PM
Could be old or low on trans fluid. If you havent had it done, have the pans dropped filter cleaned/replaced then refilled (it is NOT a sealed transmission). DO NOT have a flush done, that will most likely kill it. Or it could be the range mode sensor is dirty http://forum.planetisuzoo.com/viewtopic.php?t=1707
Edited by: Gizmo42
Old 11-20-2007, 06:55 AM
justanox's Avatar
I've seen where the range motion sensor is located and I believe I can clean it up, but does anyone have a good method of re-filling the transmission fluid after I drop the pan and filter? From what I've read in the Haynes Manual, I assume I'll have to get a Fluid Temperature Gauge to read the temp, then add with a hand pump or something? Thanks for all the info so far.
Old 11-20-2007, 04:48 PM
http://isuzufaq.ibctech.ca/#faq58
There ya go. I dont have an automatic so never done it myself.
Old 11-29-2007, 08:33 AM
justanox's Avatar
well, I cleaned range motion sensor, and it helped a little but the problem is still there. I don't think its the fluid since the dealership I bought the vehicle from replaced the fluid (they "fixed" a leak in a spring-backed "plug" on the passesnger side, which then proceeded to loosen and blow out while I was driving home one sunday evening---tranny fluid everywhere and left me stranded!) could it be the speed sensor sending bad information to the computer? and do you guys have any idea what that spring-backed plug could be?
_uacct = "UA-939292-44";
Anonymous D
Pickup
11-15-2012 07:32 AM
jackbruiser
06-27-2010 07:25 PM
Scottps
10-17-2008 12:58 AM
mario
01-28-2008 07:32 PM
OffroadAmigo
07-05-2007 11:30 AM
Quick Reply: transmission shifting problems
