Transmission Issues???
Old 05-03-2006, 01:59 PM
qnb2002's Avatar
I have a 2002 Isuzu Rodeo LSE and just two days ago the gears started slipping. Anyone out there with same issues that could give me some pointers? It's going to a transmission place tomorrow. The under carriage had transmission fluid all over underneath, but mainly by the transfer box. Hope it's minor.
I also have fuel light issues and just recently found out I only need to replace the sensor and not the entire fuel pump.
Old 05-04-2006, 01:58 PM
usedtobehappy's Avatar
Good Luck- I just took mine there and the whole transmission hand to be replaced because a seal on the side of the trans was leaking and ruined the trans. I also had the problem of my 2001 Isuzu Rodeo stalling when I stopped after it was warmed up and had been shut off once- it was the brain and had to be replaced. Now I have a bill of almost $4k (used transmission)and it has 115k miles on it. I don't think I would buy another Isuzu.
Old 05-04-2006, 02:42 PM
qnb2002's Avatar
Thanks for the info. I acutally have a 2001...typo...I'm waiting now to hear what the problem is. I will let you know. When did you start to notice the lead, issues and how long before you took it to a specialist?
Old 05-05-2006, 12:17 AM
ISUZUGURU's Avatar
Super Moderator
its called the accumulator piston cover.they all leak sooner or later on the newer trans.if you catch it early its a simple fix.part about 12 dollars.usaully the only way it can ruin the trans if someone kept driving when the trans started slipping.
Old 05-05-2006, 10:34 AM
qnb2002's Avatar
Well it's not my transmission thank goodness! It was the servo and the seals broke and have to be replaced so it's costing me $350. They stated my transmission has not been damanged. It was a good thing I only drove it two days and had it towed or there would have been extensive damage done!
felinewarrior
09-22-2008 06:08 PM
spearbang
08-11-2008 04:59 PM
92Trooper
08-02-2008 09:00 AM
DarkSideofWill
I-Mark
01-25-2008 12:56 PM
jross61975
09-30-2007 10:34 PM
Quick Reply: Transmission Issues???
