< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> Ok, I would like to tell you I didnt do this but oh well, I tried replacing my timing belt in my 1999 Rodeo. It has the 2.2 in it and as you might imagine things did not go well. What can I expect the mechanic to find who is now going to fix my mess. |
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> if you didnt time it correctly,an you tried cranking it over.you proably bent every valve in the head.thats an interference engine.hopefully you got lucky.......sorry |
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> 1500 dollars worth of parts just in the head. Mechanic told me I was lucky I didnt do nothing else to it. Oh well, 2300 w/labor, next time I get a wild hair, I will look at that repair bill. |
sometimes after someone puts a head on, you end up getting a low end knock, thats why Isuzu wanted the dealers to replace a long block assembly
