Throttle sticking on 98 Rodeo 4X4
Old 03-20-2012, 08:08 PM
elsleepster's Avatar
Question Throttle sticking on 98 Rodeo 4X4
We just recently purchased a 98 Rodeo and at times the throttle or something sticks, but when turned off it restarts normally. I cleaned out the air intake valve on the front of the engine, the egr valve and replaced the pcv as well. It doesn't 'stick' as much but wondering what else I might try before replacing parts that may not need replacing. Thanks for any suggestions.......
Today I cleaned the Idle Air Control Valve and it was pretty gunked up. I'll reply in a week or so to see if that made the fix.
So far so good....... I got a repair manual which helps a lot- cheaper if you get a used one from amazon
bigbean94
01-23-2012 04:29 PM
MD2112
10-16-2011 10:42 AM
Benjaminmt
08-30-2011 12:25 PM
daverph
10-26-2008 03:56 PM
sandyb23
11-11-2005 04:16 PM
Quick Reply: Throttle sticking on 98 Rodeo 4X4
