Smog Failure
Old Nov 8, 2008 | 12:25 PM
gnr_70's Avatar
1998 Isuzu Trooper smog failed:
At IDLE is where it is failing.
HC (PPM)
Max Ave Measure
100 17 175
at 2500 RPM PASSES
HC (PPM)
Max Ave Measure
170 13 30
Things done to try and fix and have it passed:
Removed and cleaned intake manifolds, EGR lines, NEW EGR, tune up (new plugs)...
No Vacuum leak detected.
One thing that may be causing this is a cut I made at the exhaust (upstream of the catalytic converter) because the starter gave out last year and I replaced it. The starter was on the drivers side front wheel. The only way to gain access to the starter was to remove the exhaust pipe. Unfortunately, I was not even able to loosen the three bolts to remove the exhaust pipe from the manifold and had to cut to the exhaust pipe to gain access to the starter.
I patched it up with the wrap around metal piping and used a high temp gasket maker to seal off any leak. Maybe this is what''s causing the high HC? I am not sure. Last resort would be to have it welded shut.
Can an O2 sensor failure cause high HC as well? maybe even a failing catalytic converter?
Any help is appreciated.
Thanks.
William Thomas Harris
Jul 9, 2015 06:35 AM
Karma2
Jul 12, 2012 10:39 PM
Lunchbox21984
Private 'Wanted' Classifieds
Aug 6, 2011 06:15 PM
xrayeyes00
Jul 18, 2009 11:51 AM
rommel614
May 15, 2008 08:12 PM
