Does anyone know if the 96-97 4 cyl 2.6 Rodeo engine can be put into a 88 Trooper with a 4 cyl 2.6 engine?? Does everything match up ...bolts, electrical, manifold, intake, etc..? Any suggestions??? Edited by: Dixietrooper
< =""> <! var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //> </> |
Hi Jerry!
Glad to see you on this board now. Not alot of knowledge around here so yours is much needed. |
Originally Posted by Gizmo42
Hi Jerry!
Glad to see you on this board now. Not alot of knowledge around here so yours is much needed. < =""> <! var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //> </> |
| All times are GMT -5. The time now is 09:13 AM. |
