Removing the door panel
I have a 2004 Rodeo and was wondering if anyone here has removed the door panels. The reason I ask is because I'm trying to install new speakers.. and don't want to start ripping the door apart. Any input on this would be great!
So far there is only one screw (in the door handle) that I can see. Other then that, I'm guessing it's gonna be snaps all the way around. Thanks again! |
There is a screw in the door handle, but there is also 4 additional screws under the the speaker cover. then you will have to unsnap the door and unplug the speaker and window control. should be pretty easy to do, just becareful when unsnapping the panel.
| All times are GMT -5. The time now is 08:24 AM. |
