-   -   New to Forum-Can anyone help me find? (https://isuzuforums.com/forum/rodeo-17/new-forum-can-anyone-help-me-find-36936/)
lefteye Dec 18, 2010 03:25 PM
I need a detailed instruction manual for heater core replacement on my 1994 Rodeo. Does anyone know where I can purchase this or download it? I need to be able to run some tests to determine if the heater core is bad and then if it is how to remove and replace it.
Thanks, Lefteye
hr2burn Dec 18, 2010 09:10 PM
I haVe a repair manual that covers this but it's pretty involved for me to type it all up...
But 1st of all is your hester core leaking? What is your reason to need to remove? To possibly jump ahead, have you felt the in out coming from the core? When the engine is at operating temp, are both hot? Easiest access is going through firewall. I'll help ya through this if ya like....I'll just have to type like a madman.
Sean
hr2burn Dec 18, 2010 09:28 PM
If nothing else, check this out.
http://forum.planetisuzoo.com/viewto...381&highlight=
lefteye Dec 19, 2010 09:21 AM
hr2brn, thanks for responding. I found the passenger side floor board soaking wet, so I assumed it was the heater core. I by-passed it to stop the leak and allow it to be driven until the repair could be done. I didn't do any of the testing as you described before by-pass. I would appreciate your help but is there any other way to send me the info without all the typing? Maybe making copies then faxing? Or any other suggestions? I did find another link that described replacement on a different vehicle : http://forum.planetisuzoo.com/viewto...ht=heater+core
Would the steps be the same for my '94 rodeo?
Lefteye
hr2burn Dec 19, 2010 10:02 AM
I would think very similar, put cannot guaranty it. I suppose I could scan the pages and email? I will work on it...in the mean time, have you ordered a new core?
lefteye Dec 19, 2010 10:39 AM
Not yet, I've been looking online at a few places....do you have any suggestions?
hr2burn Dec 19, 2010 05:36 PM
I've had good luck with these guys...
http://www.autopartswarehouse.com/sk...%26+Drivetrain
