need help with speedometer....
Old Apr 8, 2006 | 04:15 PM
burnmaster's Avatar
speedometer was working fine...parked overnight and the next morning the speedometer wasn't working....
is there a relay or fuse for it?
I have changed both parts(speed sensor and the speedometertrasmitter)on the rear oftransmission, but didn't fix it..
It is a 1994 rodeo 6 cyclinder, electronic transmission, 2 wheel drive.
thanks
Old Apr 14, 2006 | 07:39 AM
Wiseguy's Avatar
I would also like advise. I have the same issue.
Old Apr 20, 2006 | 05:07 PM
burnmaster's Avatar
I geuss we are the only 2 ppl that has ever had this problem....
Old Nov 15, 2010 | 04:13 PM
Oldman's Avatar
I've got the problem, but this forum seems to be 99% reporting problems and only 1% providing solutions. Either of you figured it out, or are we just 3 folks driving these beasts depending on folks around us to let us know what the correct velocity is?????
Old May 21, 2011 | 08:17 AM
tallpine's Avatar
1994 Trooper 6cyl manual trans. My speedometer does not work when I first start then after 5 to 30 minutes it will start working. I bought a GPS and use it's MPH function. I pencileon my dash an RPM to MPH list for the important speeds, school zones, general speeds.
so now 4 of us
Old Dec 19, 2011 | 05:14 PM
lfausty's Avatar
5 intermittent speedo
Old Jan 10, 2012 | 10:56 AM
timeskep265's Avatar
i am having a simular issue, i just got on here, mine is when the car gets hot (from driving) the speedo will bounce around and eventually just drop to zero... i thinkin its also because my trans fluid was low, but i am not sure yet
billmarti
Apr 1, 2009 08:31 AM
Swflbt19
Sep 19, 2008 06:17 PM
qha000
Jun 5, 2007 02:00 PM
skout4lyf
Jan 24, 2007 09:54 PM
erez
Dec 12, 2006 08:43 PM
