More Timing Belt Issues
Old Sep 3, 2008 | 04:59 PM
Campingrich's Avatar
My son, 29 years young has a ''98 Rodeo. It had a howl coming from the front of the engine and replaced the water pump to fix it. Well that wasn''t it and now we are having trouble getting it to run correctly again.
We carefully set the overhead cams and the crank in the aligned positions and installed the belt with lines as indicated in the manual. Did it four times. It will run but when placed in gear and gas is applied it kind of backfires. Seems to still have a timing problem.
Any suggestions?
Thanks
Old Jun 24, 2009 | 10:26 PM
tjhennin's Avatar
I am having the same issue after replacing my water pump. What did you discover? I can't seem to get the timing right.
waphill
Oct 5, 2012 03:19 PM
Todd H
Dec 15, 2006 07:12 PM
ephebus
Sep 8, 2006 03:18 PM
Thumper
Jul 2, 2006 06:25 PM
Keytonic
May 21, 2006 04:43 PM
