Love my Rodeo can't find coolant leak
I have a 98' Rodeo with 218,000 miles and love this truck. The only thing is for over two years i would have to add coolant to the system every few days but if i drive long distance on the highway it doesn't use any coolant. The radiator finally clogged up and i replaced it. the clutch fan was loose so that was also replaced. sadly the new clutch fan is a lot louder then the old one, i don't know why. but back to the real problem i can't find the leak. The radiator doesn't seam to build up any real pressure but there is no water on the engine, on the ground, in the engine oil, around the water pump, so on. There is one other thing, I don't get much heat from the heater. where i live it really doesn't get that cold. but i can hear splashing under the dash sometimes. The engine never over heats.:cool:
