Location of ABS Control Module
</>Where is the ABS control module located on a 2001 Rodeo? Is there anything difficult about changing this?
Isuzu says that mine needs to be replaced, based on the error codes that I have.
_uacct = "UA-939292-44";
</>Edited by: dane
good luck on that. am looking for the same thing on an 01 rodeo 4x4 sport. have half the interior ripped out and still no module. haynes manual says it is under the seat but no module under any of the three seats in it. will notify if i find it. what codes do you have and who did you talk to, isuzu told me they were not allowedto share "technial" informaton with me.
Thanks chris
I don't have the specific information, but I had a low voltage and rear sensor code. They said the combination of these indicate that the ABS Control Module is bad.
From what I have seen, it is the unit under the hoodthat pumps the brake fluid. I guess it has the electronics inside. If this is the culprit, it looks like I will need a mechanic.
The only problem that it really causes is that the ABS light comes on intermittently. It seems to come on more often when the weather is hot.
