I have a 1995 isuzu rodeo that is leaking coolant from a trasfer line that carries the coolant from one head to the other. It is actually leaking in the back between the engine and firewall. Iv'e been driving it okay to work for a few days by just adding a little coolant each time before driving. Now the leak is getting a little worse. Is there any kind of stop-leak that I can use as a good temporary fix? Just need to drive it a few more days till I can get paid and have it fixed. Any help would be greatly appreciated. Edited by: kallen2412 |
Stop leak wont help. Either the hoses or o-rings for the metal tube that run under the intake are worn out. About all you can do is continue what you've been doing until you can get it fixed.
Make sure they replace all the hoses under there as well as the o-rings. Maybe even the heater hoses, they will probably fail soon too. Its pretty involved getting the intake off to replace them all so might as well only pay once for the labor. |
