Here is a 1992 Isuzu Rodeo V6 4x4 5speed manual it has 139xxx miles. It has had all brand new gaskets under the hood from the head gaskets on up as well as a new radiator,new water pump, new hoses, new thermostat, new alternator, new brakes and a new clutch with less 500 miles on them. It also has brand new
29 1/2 inch mud terrian tires with less then 200 miles on them. Recently painted about 1 year ago.This truck was used for work but i just got a new truck and no longer need it.The Truck runs very good and is very strong the only problem is it needs a drivers side brake caliper and it has a small exhaust leak both are easy fixs.I NEED TO SELL ASAP I NO LONGER HAVE THE ROOM TO STORE THE TRUCK IT NEEDS TO GO RIGHT AWAY..... |
[QUOTE=philly061500]Here is a 1992 Isuzu Rodeo V6 4x4 5speed manual it has 139xxx miles. It has had all brand new gaskets under the hood from the head gaskets on up as well as a new radiator,new water pump, new hoses, new thermostat, new alternator, new brakes and a new clutch with less 500 miles on them. It also has brand new
29 1/2 inch mud terrian tires with less then 200 miles on them. Recently painted about 1 year ago.This truck was used for work but i just got a new truck and no longer need it.The Truck runs very good and is very strong the only problem is it needs a drivers side brake caliper and it has a small exhaust leak both are easy fixs.I NEED TO SELL ASAP I NO LONGER HAVE THE ROOM TO STORE THE TRUCK IT NEEDS TO GO RIGHT AWAY..... https://images.craigslist.org/14913b...8ede9313ec.jpghttps://images.craigslist.org/1f71g5...5265601c9a.jpghttps://images.craigslist.org/1g7134...55c544153b.jpghttps://images.craigslist.org/1f0140...2d16f71e80.jpg |
where is it located and how much do you want for it?
ITS LOCATED IN PHILADELPHIA, PA I AM ASKING $1200 i have spent more then that with the clutch and tire alone..
Let me know if you still have this for sale. I am in Bucks county PA.
YES IT IS STILL FOR SALE IF YOU ARE INTERESTED GIVE ME A CALL AT 267-322-8610
