How much can I put in the back of a rodeo
I just purchased a 99 Isuzu Rodeo LS 4x4. I need to haul an engine, and I
don't really want to drag a trailer around. Anyone think that 800lbs would be
to much to put in the back end of it? I'm new to the foriegn vehicle with a
gas engine thing, so thank you in advance for any advice. I usually drive a
diesel, but the tranny just went out of it, so I'm stuck with the rodeo.
It should haul it just fine as far as weight but you might be on the bump stops with stock springs. The stock ones are kinda soft. When I moved I had an over loaded 6x12 enclosed trailer, dont know how much weight was actually on the hitch but I was on the bump stops the whole way. Didnt seem to bother it any.
< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-4</>99 rodeos new were rated for i think 800-900 lbs max payload but i own a 96 rodeo so not 100% but i do know i can haul 900lbs with tires aired down an mine rated for 885lbs new but i don't recommend this for long hauls i only want 20miles with tires at 30psi instead of 45psi my crappy highway tires need.
Hope this helps
Mike
Hope this helps
Mike
Regena.toby
Sights 'N Sounds
Mar 13, 2012 05:43 AM
