How to change rear axle?
I am working on a 2000 Isuzu Rodeo and need to change out a bent drivers side rear axle, I have the new axle and bearing kit (seal,bearing,spacer?). From what I have been able to find out so far is I need to remove the wheel,breaks, and seal retainer nuts. Then the axle should come out. Does anybody know if this is correct? Is there anything to I am missing? Thanks in advance.
Thanks man for guiding about changing rear axle.
that will helps me |
