hot oil smell
Old Oct 19, 2009 | 06:36 PM
Doug I's Avatar
Default hot oil smell
97 V6 auto
Does not burn oil, does not drip any either and the pressure is around 50 psi. Temp is where it's always been and is good. When it's up to operating temp and stopped it smells of hot oil. Does not smell in the cabin under any combo of fan, heater or AC. It only smells on the outside. Ideas?
TIA
Old Oct 19, 2009 | 08:37 PM
wheily's Avatar
mine does that to never have figured it out of corse mine is a 88 with 286,000 on it id try and replace pvc could be a blow by isue not venting right
Old Oct 30, 2009 | 09:43 AM
coleman's Avatar
My '95 does it, and the culprit is bad valve cover gaskets. You have to let it sit a few days and some oil build up to see where the smoke is coming off the exhaust manifolds. If you just keep driving it the oil burns off too gradually and won't actually smoke.
Old Nov 3, 2009 | 05:33 PM
paulwschubert's Avatar
my 96 had that problem. valve cover gaskets. after the repair your going to have to clean the engine where the oil leaked or it will continue to burn off for a while and you will still have that smell.
Old Nov 7, 2009 | 07:23 PM
Doug I's Avatar
thanks everyone. Got out there with a mechanics mirror and yup it's a weeping gasket way round the back. Nothing I'm overly worried about just yet as it's about a 1/4 pint every 3k miles that's disappearing.
Dustin102
Feb 15, 2012 04:24 PM
98 amigo
Nov 12, 2011 06:29 AM
mreed1587
May 26, 2011 03:48 AM
Dennis
May 23, 2007 07:25 PM
helpamom
Sep 27, 2005 07:28 PM
