Help! 1999 rodeo coolant leak
Hi All. new to this forum and i could use some help.
I have a 1999 Rodeo with a coolant leak. While driving home from work I noticed the temp rising. I got home to the hissing sounds of steam and noticed coolant splashed around the engine. Is there anyway I can tell if this is a hose or where the leak might be coming from? I'm a novice mechanic at best, but I can turn a wrench, swap a part and follow instructions. Appreciate any advice. |
Fill the radiator with water and see where the leak is coming from.
| All times are GMT -5. The time now is 03:45 AM. |
