Heater fan NO work, is there a relay?
I went to start my rodeo this morning (95 4wd) and i go to turn on my heater and the fan doesn't come on at all. I smelt a slight burning smell and figured that was what it was before i even did anything. Since i am relatively new to the isuzu rodeo scene, im not sure what the problem could be. I would hope there is a seperate fuse or relay that controls the fan for the inside of the car that blows the heat/AC but i have no idea. If there is, can someone tell me which number fuse it is or where the relay is for heat/AC or whatever I need to do.
Thanks, Justin
Probably the resistor pack for the fan burned up. I havent had that problem so dont know for sure where it is but suspect its mounted to or around the fan motor. Have seen posts about them burning out and needing replaced.
