Door won’t open
Old 08-09-2007, 08:50 AM
wolfhuskies's Avatar
The driver's side door is locked and won't open. Tried the key from the outside, and pulling the button from the inside. I assume the linkage is broken inside the door. How do I get the door open so the door panel can be taken off? What linkage is probably broken? If I can find a lockout tool, how do you use one?
Old 08-09-2007, 03:09 PM
jugganaut's Avatar
i've only had my '94 rodeo a week, but i saw a series of screws at the bottom of the door. you may have to pry the cover from the kick plate to get at them. hope that gets you under the panel
Old 11-13-2007, 11:53 AM
Can I do that without opening the door? I can't even get the door open. I borrowed a slim jim, but I'm not sure how to use it. Anyone out there know how to use a slim jim on a rodeo?
Old 11-13-2007, 07:57 PM
XR400R's Avatar
Never used a Slim Jim, but I have opened mine with a bent coat hanger. Not difficult. Just slip the Jim into the door at the latch & gently lift up on the angled connector just below. This pic by someone else gives a pretty good idea of where to lift.
Dannyboy8119
07-21-2015 02:57 PM
the wolverine
02-08-2009 03:48 PM
jaypb
01-23-2009 10:41 AM
Middawg2
09-07-2008 08:38 PM
IsuzuKid
07-17-2008 10:25 AM
Quick Reply: Door won’t open
