Engine start up out of car
Hi
Would you be able to help me out with an engine problem I have?
I've rebuilt an 2.6 Isuzu (4ZE1). Before I put it back in the car I want test it and check for any problems. So I've got a battery put the positive to the starter Moyer and the negative to the engine block. I've seen on a iTunes clip that a lead goes from the dizzy to the negative of the coil then from the coil to the positive on the battery.
However the dizzy I have has no connection to come off to the coil.
Thanks
Thanks
leobubenheim
IF Help & Suggestion Center
11-04-2016 07:08 AM
airenbrown
11-21-2011 04:29 AM
