-   -   crankshaft pully (https://isuzuforums.com/forum/rodeo-17/crankshaft-pully-1467/)
barber1 Nov 3, 2007 04:08 PM
I have a 1998 rodeo and an trying to replace the timing belt I am at the crankshaft pully and the pully bolt wont seem to break loose I am not sure if I am to turn it clockwise or counter clockwise. It is a 3.2 engine can anyone help.
XR400R Nov 3, 2007 04:53 PM
Counterclockwise.
I used an impact gun on mine, & it came right off with no difficulty.
I have heard tell of guys who have used a very long flex handle attached to the bolt, with the other end resting against the drivers side frame rail. Then bump</span> the starter (don't let it start, for goodness sake!) &amp; let the starter torque break it loose. Never tried that myself, but others say it works well, if you don't have access to impact gun.
barber1 Nov 3, 2007 09:04 PM
Thanks for the info XR400R that will help greatly[img]smileys/smiley4.gif[/img]
