clogged catalytic converter? need help
Old Feb 14, 2010 | 11:07 PM
KDemarest7725's Avatar
Exclamation clogged catalytic converter? need help
I just bought a 95 isuzu rodeo 3.2 V6 4x4 with 123k miles and when i bought it, it needed a tuneup so i changed the plugs/wires. drove good for about a week and then just started running like crap one day on my way to class. It now will not go past about 3k rpm and is VERY sluggish. Takes a long time to start it also. I have replaced EGR, MAP, coils, fuel injector cleaner, changed oil and filter, and still nothing. No CEL is on either. The bulb works fine because it lights up when i turn the key to start it. Have had a few people say it was a clogged catalytic converter and some say it is crank postion sensor. But if it was a sensor wouldn't it throw a code? and plus i cant find where the crank position sensor is located! Some help with this please!
Last edited by KDemarest7725; Feb 14, 2010 at 11:10 PM. Reason: left some info out
Old Feb 15, 2010 | 02:13 PM
chrishawk's Avatar
crank position sensor is located passenger side of block right under motor mount. hope this helps. I would try to swap it, if it fixes great. If not return that bad boy and try that cat.
Old Feb 15, 2010 | 04:09 PM
just pulled the cat off and tried to start. still the same thing. but now the check trans light is flashing. Why would the trans light be flashing if it shifts fine? Just REALLY hard to start and when it does it runs like crap. Idle is fine but when i touch the gas it sounds like the intake is sucking alot of air than normal. Still won't go above 3k rpm also. I am lost here people and really need this truck running. Any help would be very appreciated!
Thanks for the location. I'll go check that out now!
Old Feb 16, 2010 | 12:10 PM
chrishawk's Avatar
well you said you pulled the cat off and the trans light came on, not sure where the o2 sensor is located ( before or after cat) but if after that could explain that light. Umm try spraying carb spray around the intake where it actaully bolts down. If it starts to rev up or maybe bog down you could have a bad intake manifold gasket. let me no what that does. also try cleaning you mass air flow sensor and throttle body
Old Feb 17, 2010 | 09:07 PM
ok cleaned everything today and nothing. actually couldnt even get it started today. the check trans light came back on after trying so many times to start. If it is blinking cant i check for a code? it is a pre 96 though. so does that mean it isnt obdII? can i even check for codes on this thing without taking it to the dealer? still havent replaced the fuel filter yet though. hopefully thats it.
Old Feb 22, 2010 | 09:33 PM
Algopsy09's Avatar
Default clogged catalytic converter need help
Hi all, im having trouble with the replacement of my catalytic converter, the cat and front pipe currently is one piece, however when i came to order a new one the supplier reckons i need to fit the front pipe and cat seperatly at a cost of £70 more, i dont wanna buy the full system and then have it not fit properly PLEASE CAN ANYONE HELP Cheers ben
Old Feb 23, 2010 | 10:18 AM
Cracker's Avatar
usually, i suggest cutting the cat, and running a straight pipe
Old Aug 25, 2010 | 10:10 AM
  #8
RodeeYo's Avatar
I had a similar starting, running only low RPMs issue a couple times when mine was fairly new. Turned out the intake manifold gaskets were leaking. Both times covered under warranty.
Mine now needs a new exhaust - for certain. Don't want to hijack the thread. Will post new topic.
Jworkman1991@gmail.com
May 3, 2011 03:17 PM
DyingRodeo
Jul 29, 2010 12:51 PM
kdfvwman
Oct 11, 2009 07:19 PM
gun7369
May 26, 2009 06:42 PM
dane
Aug 24, 2006 10:43 AM
