-   -   Clicking Behind Rear Wheels (https://isuzuforums.com/forum/rodeo-17/clicking-behind-rear-wheels-38410/)
brek08 Nov 12, 2011 12:40 PM
have no idea what it is. Its coming from the back so i know its not the cv's. checked the brake hardware and it looks fine. could it be something to do with wheel seal or the diff?
brek08 Nov 12, 2011 12:43 PM
Its a 95 4x4 by the way
brek08 Nov 22, 2011 04:28 PM
figured it out. just replaced the rear seal and diff gasket and filled her up. it was probably just some wear on the spider gears but works great now. so if anyones having the same problem, there ya go.
f10078 Nov 23, 2011 03:30 AM
just replaced both rear axle bearings still getting clunking noise when i test drove, did notice the pinion gear was a little loose when i replaced the pinion seal, what could cause the pinion gear to be loose on a 1996 rodeo w/dana diff?
Taylorcarter Dec 9, 2011 09:51 AM
Its looks like a great one. I feel it will be a good option only.
